Rotate the disposal counter clockwise about 45 degrees.
Install a santée where the back end of the S was. Rotating the disposal and the p-trap will give you room for the trap arm into the santee.. maybe if you just rotate the trap out might give you the room you need with out rotating the disposal. the just offst up from the santte to get the AAV up to the back corner as high as you can
