Help Needed - ORB Bathroom Sink Drain Flange
mr.blueskies
Sep 18, 2024
Idaho
Hello, I am hoping someone can help me. I am trying to locate a replacement part for my bathroom sinks. I have an ORB snap in cap or flange that sits on top of the drain itself (which is chrome). I have spent hours searching the web and visiting local plumbing stores such as Ferguson and Standard Plumbing supply but no one has seen this particular item. Perhaps it is too old or from an off brand. I really appreciate any assistance. Thank you in advance! Todd
Replace the entire drain.
Right. The parts are very cheap and available everywhere. Modern ones don't even require any plumber's putty, as they are gasketed and designed for a homeowner to change generally with no tools.
If a modern one doesn't fit for some reason (I don't know why it wouldn't but then again I have not tried) replace the sink!
Thank you all for the suggestions. I have replaced all of my standard bathroom sink drains. I have two pedestal sinks that will require complete removal in order to replace the drain due to limited rear access. This means some touch-up paint work etc on the wall which I was trying to avoid. At this point I have taken the two best flange caps from the other sinks and placed them on the pedestal drains until I am ready to tackle them. Thanks again.
