Ted dummy/genius
Hi All,
I've built an accessory dwelling unit with a full bathroom. The 3" waste line is pitched under the slab into a Liberty pump grinder/ejector (Provore 380-SD). The ejector is buried in the ground just outside the building structure and as per the installation instructions, a 2" SCH40 PVC pipe runs buried in a trench 100' back to the existing plumbing in a crawl space under my house.
Right now I have it stubbed out into the crawl space. I have two possible places to connect it. This is where I need help.
I hope I can figure out how to attach my pictures and drawings to illustrate...
The easiest place to connect is a straight shot to the 2" ABS master bath waste line which feeds into the 3"ABS toilet waste and then exits to the sewer. I'd come into it with a long turn Tee Wye fitting. Just not sure if that's allowable.
Second option is to run it further with a few more connections to get it to connect via a long-turn Tee Wye fitting to the 3" toilet waste line.
Any thoughts or guidance would be super appreciated.
Many thanks.
Ted
Many thanks.
Ted
