toomanyfilters
Forgive me if I don't use all the right terms, I'm a female and trying my hardest not to be clueless.
Located in NH. Well is less than 3 years old. We have a greensand filter and a sediment filter (sediment filter is after greensand) and we are still getting manganese in our water.
After 1.5 years we started getting orange tinted water again. Filter company came out and replaced the filler within the greensand filter and also added a sediment filter.
I waited over a month for the orange water to go away, and it did, in the cold water but we were still seeing it in the hot water only. So, we drained the hot water heater 4 times. It didn't clear up the water.
We got a new coffee maker that required us to run just water through it before using to brew and we noticed that we would put in cold, clear water and out would come orange tinted water. So, we put some cold water into a bowl and microwaved it. It came out orange tinted!
Called the filter company again and they came out and took samples. Here are the results after being filtered:
Iron .26
Manganese .209
Total Harness 25
PH 6.39
Tannic Acid <.2
Do any of you fine people have any ideas what we can do to remedy this issue? I have cockatiels and I'm worried about the Manganese with them drinking the water.
Iron .26
Manganese .209
Total Harness 25
PH 6.39
Tannic Acid <.2
