I know that pushing pipes into connectors fully is the required way to make connections with ABS pipe.
However, I have a situation with the drain pipe being about 1/2" too short leaving only about 1" of the 1 1/2" flange pipe going into the drain pipe.
Any thoughts on the minimum amount of abs pipe that should be in the hub to make a solid connection. Is 1" okay or should I extend the drain pipe?
Thanks
Thanks
