In my infinite wisdom, I did not realize the need for a nut-coupling in my supply line going into my back-flow prevention unit.
The water supply was not shut off before winter and as you can imagine, I now have a burst valve going into the back-flow device.
I really don't want to have to dig a hole down to the main; is it possible to unscrew the split valve while leaving my supply line intact or will I have to cut it?
Details: galvanized supply going into brass back-flow assembly
