Frozen hot water line and no pressure now
WildWoodWeed
Jan 22, 2025
Kentucky
We woke up to frozen pipe(s) as it was -15 here in Kentucky. We can unthaw the hot water line and have both lines open, but there is almost no pressure. Water has been checked by the water company. Water pressure is fine in other location (same line), just bad inside the house. Never had an issue like this lol and have dealt with frozen pipes for 50+ years. Close hot water faucet and the cold has plenty of pressure (normal), we just found this out
sorry to be a simple answer guy here, but, diagnosis is step by step to isolate issues. If pipes have no break, water flows when there is no blockage, simple physics. Sorry you are having trouble.
Thanks, I really appreciate that! We have only been here a few years and most of the house was built with good ol' redneck engineering, so we are still trying to figure out where all the pipes have ben run.
Open all sink cabinet doors to get heat there, remove the aerators just to make sure they aren't clogged you could use a hair dryer and point it at the water pipes and the wall you should have someone at the water meter just incase there is a break
