FHW supply line
recruiter
Jan 6, 2016
I have a 110 year old multi family house that has asbestos covered FHW supply and return lines feeding radiators on the first floor. (BTW: the asbestos is already encapsulated). The previous owner uncovered the 1 1/4" pipe, to a fitting, then connected copper reducers down to 3/4" in order to install a Slantfin 4 ft. baseboard radiator in the bathroom. Due to major renovations that are needed in the bathroom, I will be replacing the baseboard heater, since it was damaged during the renovations and the copper connections now leak at fittings.
I am looking to replace the copper with Pex.
1. Is the original 1 1/4" piping black pipe? 2. If so, will I be able to use a black pipe 1 1/4" to 3/4" reducer directly to a Pex brass connector without an issue of corrosion or electrolysis? 3. What would I use on the threads? Is tape OK?
Thanks
Dave
From what I see, I have a two-pipe direct return system.
I live in RI, USA.
We purchased this house in 1999, complete with all the former owner's mess-ups, which we have been trying to fix, one project at a time.
This baseboard unit is the last unit on the loop. I am not able to tell if there was originally a cast iron radiator like the rest of the apartment, replaced by this baseboard heater, or if he simply decided to tap into the line and add a new baseboard unit to it. More than likely, it was the first situation. Now I'm stuck trying to figure out how to work around it.
your heating lines are sized to deliver X gpm at your baseboard/infloor heat/fan units.
if you choke the system down by cutting out a section of 1 1/4 and replacing with 3/4 pex
which is actually 1/2'' ID you are seriously f--up.
you said the other owner did it. that is most likely your problem now.
the unit that is being served is not getting enough hot water flow {gpm} to be efficient
any time you transition from steel pipe to copper/brass you must use a dielectric union or nipple
it will rust out at that transition, if not
I checked this out, again. It is actually an old gravity feed system. The boiler was replaced several years ago, and it now has circulator pumps installed.
I actually found the 2 original fittings that were removed to install the baseboard heater. Curiously, it is a 1 1/4" Tee (capped at the end) with a 3/4" leg. When I checked out all the other radiators in the apartment, they are all running on 3/4" pipe.
At first I thought there may be a 1 1/4" loop somewhere, but it's not the case. There are 2, 1 1/4" feed and return lines with 3/4" branches to each radiator.
Is this normal? What is the difference between the setup with the radiators vs. the 3/4" copper tubing for the baseboard that the previous owner installed?
Thanks
