Gage Lamar
My water heater is leaking somewhere from the bottom. The cold water inlet and drain valve are both located on the bottom I sealed around both of them with gasket maker I went over the seams on the cold inlet and drain several time so I wouldn't leave any holes yet still have a leak in I put boiler leak sealant inside the tank and connect drain valve to the hot outlet and let water circulate for a while then drain and refill? Would be safe? I can afford a new water heater
