Two days ago, the water suddenly quit working. There was no water pressure, only what was left in the pipes. It was as if the power had gone off. So I shut off the breakers, and a family member went and whacked the relay a few times with a screwdriver. I turned the power back on, and the water worked. He attributed this to his whacking. Water worked fine for a day, but today it suddenly quit working again.
So what does he do? Go whack the relay again without turning off the power. To my horror, I saw the lights flicker in quick succession. I honest to God, thought he got electrocuted. I ran outside; thankfully, he was perfectly fine somehow. He said the screwdriver started arcing off the relay. The breaker did not flip when this happened. From what he said, he touched the screwdriver to the top coil looking part of the well relay.
I'm sure this damaged the relay, but relays are cheap. I'm concerned if it could have fried the well pump since it's connected to the relay. Water hasn't worked since, but it wasn't working before.
Update four hours later: Water just started working again out of nowhere. There haven't been any kind of fluctuations in the water pressure that I've noticed. It either seems to work fine or doesn't work at all. I'm hoping it's the relay that's causing the problem. The relay looks in poor shape; it's started rusting (live in the rust belt) and has grime buildup from being under the house.
