APOLOGIES
Sorry I have not replied to ALL of you before today.
My wife has just had her third lot of major surgery for cancer. For about 6 weeks I have had to put all my time and energies into nursing her and being a house-husband.
Not an easy time for either of us.
And then about 4 weeks ago my left knee gave out. Very sore and impossible to exert any pressure on it. I ended up having to buy very expensive GEL type knee pads, which sort of gave a little relief but I just had to stay off my knees all together.
A lesson in "protective clothing" . . . . Wise
after the event!
PLUMBING
Water in the line is the obvious culprit. And I really had ignored the steam issue. I have been making sure I remove a fawcet-spindle some where in the line to allow for air expansion ... nothing more frustrating to watch air pressure slide a hot joint apart, in a closed system.
@ chrism . .
You raise an excellent idea to use pre-soldered fittings.
I have some 30 year old brass pre-soldered fittings (left over from my very first attempt to solder). I have steered clear of using them because the brass requires a lot more heat (due to its mass) than copper fittings. Too much heat and I anneal the copper pipe creating a weak point to fatigue and fail (current dry joints are in a hot water feed).
I was also trying to adhere to a leadless system (we are not subject to leadless law here yet) but I have decided to just use pre-soldered copper if I can find it.
Our local massive hardware depot does not stock pre-soldered fittings at all.
@ jwwing
I have a few sticks (½inch thick) of leaded solder I have had for about 30 years. I am so tempted to just flood the last difficult join with solder, because any wire solder (bent into an "L" shape to touch the top of the joint) reaches its "end".
Laying on my back (cannot sit or even prop up) there is 2½ inches of head clearance to the fitting.
Sharkbites.
I don't have much faith in them. As a general contractor I have had callouts by insurance companies to repair buildings where "plastic" stuff has failed. Some of them Sharkbites. And under the house/floor I would never know there is a leak until we developed damp problems in carpets and walls.
Sharkbite end stops have been handy while building the new system. I cap off the end and water test the system so far. Which was a good idea to start with until the pipe work got more complex and I have hit long horizontal runs of pipe slowly feeding water into new hot joins. Steam and wash-outs of flux!
I made up a device using Sharkbite stops and a garden hose connection to test prefabricated manifolds. It works a treat. My problems started when trying to install the manifolds into the system.
< photo of test gear >
FINAL SOLUTION
I am going to shut the entire hot system down and drain it entirely. Disconnecting the line at the HWS and remove every faucet spindle in the house to allow drain back.
Then install a number of the plugged Tees into the lines at lowest points. About 4 in all.
Then use chrisms's idea of pre-soldered fitting for the difficult access points.
I am hoping to get some help for my wife for a day while I tackle the last three joints.
Thank you to every one for your support. I will be back with a report which ever way it finishes.
Regards to all
Bawldiggle .. the bald won
