fixitron
I have a client with a drilled well, pumping to a pressure tank in the house. Coming off of the pressure tank is a separate line that supplies water to the barn (roughly 150 ft. away), using 1" black plastic water pipe. There is a water leak in the buried line somewhere between the house and barn. The line has ball valve shutoffs in the house, just before the line goes into the ground, and in the barn, shortly after it comes out of the ground. I have attached a 0-100 psi pressure gauge to the hose bibb located between the shutoff in the barn and another ball valve shutoff on the downstream side of the hose bibb, allowing me to isolate just the line between the house and barn and measure the pressure. With the pressure tank in the house at 50 psi, and the line open up to the second isolation valve in the barn (the one downstream of the hose bibb), I shut the isolation valve in the house and go to the barn and watch the pressure gauge. In about 5-6 minutes the pressure slowly drops to about 10 psi (and I stop watching it). The leak is not at the gauge or hose bibb. or the isolation valves.
What I would like to do is to estimate the rate of leakage. Knowing the diameter of the piping and length of piping, I can calculate the enclosed volume. I would think that there would be a way to correlate rate of pressure drop to rate of leakage, which would allow us to determine whether the leak is large enough to spend thousands of dollars to run a new line. Any thoughts?
