jimp
Due to a low yield well I'm adding a 500 gallon water storage tank to my system. My current setup is a 1/2hp 2 wire submersed pump operated by the standard setup of a pressure switch with a 90gallon (I think) pressure tank. My plans are to move the pressure tank on the output of the storage tank (placed after a new external 2nd jet pump which has it's own pressure switch) and to install an electronic float valve on the storage tank to regulate the filling of the tank. My question is does this electronic float valve replace the pressure switch I currently use (before the storage tank) and have wires that run to a control box that I also plan on installing with a preotective kick-off switch? And would a control box work on my 2-wire submersible pump? I'm fairly sure it's a 2-wire and not a 3-wire due to my inderstanding that a 3-wire would require a control box to work and I don't currently have one.
[email protected]
[email protected]
