I’ve had many service calls for no hot water end up being a leak under the slab.
it happens.
it happens.
Thank you for that confirmation - I was thinking/hoping that 208-210 was not uncommon.208 is the voltage you get across two phases of a 3-phase system. Most (all?) “240-volt” appliances work just fine on 208, it’s not that uncommon.
It would heat with low voltage just at a reduced rate. The wattage stamped on the element is if you apply the voltage also stamped on the element.Thank you for that confirmation - I was thinking/hoping that 208-210 was not uncommon.
hey, brag away, I'm sure you would, totally!I’m not bragging but I would’ve had your problem diagnosed within 10 minutes of being in front of your water heater.
Well, would like to think that - but it is condo dependent. I was told by the association that their responsibility ends at the point in which the cold water enters the condo, at that shutoff ....Just a thought
remember any leak under the floor in the condo is the condos association's responsibility, not yours.
So there’s power going into the tank, which means it’s heating the water, so that’s good. Are the fittings on the tank hot to the touch? You could have a leak, but there are some other diagnostic steps you could take. I would: Close the outlet valve and crank both thermostats to their maximum. Check with your voltmeter when each section turns off (and confirm with your ammeter that each element is drawing current when there’s voltage applied). How long does that take? Now open the outlet valve, do you hear water rushing to fill the pipes? If so, you _may_ have a leak. Run the hot water at every sink or shower one at a time and see if you get hot water. Try turning off hot and cold shutoff valves at sinks, toilets, clothes washers, anything that uses water for a day and see if the issue disappears.pulling over 3000 watts
Under the floor is theirs... I had a pipe banging inside a wall and made the HOA repair it. You are only responsible for the living space, not under it.Well, would like to think that - but it is condo dependent. I was told by the association that their responsibility ends at the point in which the cold water enters the condo, at that shutoff ....
I'm trying to get a copy of the condo docs to confirm that and guessing the insurance company will confirm too.
thanks for the thought, appreciate it.
It would have taken me a few hours, but IANAP. 8*) The two plumbers you hired before should be in a different line of work.I’m not bragging but I would’ve had your problem diagnosed within 10 minutes of being in front of your water heater.
Entirely depends on your condo association and the legal paperwork you all signed. Every condo association will be different in some way.Under the floor is theirs...
Just curious why you think this is a universal truth? Unless your condo association in Delaware and the OPs condo association in Florida have something in common, his rules and governance might have nothing to do with yours.Leak of a supply line, that's located in the slab - is a common element - repair is Condo's responsibility
You are quite right.Just curious why you think this is a universal truth? Unless your condo association in Delaware and the OPs condo association in Florida have something in common, his rules and governance might have nothing to do with yours.
