pgrillo
I am not a professional plumber. We have had 2 plumbing companies come in and look at this and unable to figure it out. I have done as much testing as possible - and am clueless as to what is happening.
30 Gallon Water Heater. 2 years old, dual element
Suddenly it will not heat water to hot. Get very luke warm water for about 30 seconds, then goes to cold.
Both elements and thermostats replaced by first plumber. A new set of thermostats replaced by second plumber.
Testing procedure and results and comments.
With digital tester
I have adjusted the temp down, and can see that the voltage/current goes off when the thermostat goes almost all the way down to off. Conversely, when i turn the thermostat back up, it kicks on about fairly quickly, indicating that the water is warm only and thermostat recognized it and you can here and measure the voltage on the element.
There is no kind of current regulator placed between breaker and water heater. The above is the extent of any of my knowledge on electricity. Question. Even with a reading of 209Volts and 14 ohms at the element that has been tested for continuity, etc - is it still guaranteed that the full 3100 watts is being drawn? Is there any situation in which that is not the case? Is 209 Volts enough? This water heater is not mine ... my water heater works fine and measures about 211 Volts, so I figured the voltage should be sufficient - and worst case it just takes longer to heat water appropriately.
At wits end, don't want to replace water heater if it isn't the water heater ....
Has anybody seen this odd situation?
regards
With digital tester
- Voltage reading at top (before top thermostat) is 209 Volts. 0 volts when breaker is turned off
- Top Element and Bottom Elements
- With power off, remove wires.
- Get continuity pole to pole
- Ohm resistance is 14 ohms
- Checked each pole for a short - no issues
- Power back on
- Top element. Turn thermostat all the way on, get 209 Volts reading at element
- Top element Turn thermostat all the way down, get 0 voltage at top element
- At same time I turn lower thermostat all the way up, and i get expected 209 volts on lower element.
- It appears that voltage readings at each element working properly. top on when needed, and when top is satisfied, power is routed through lower thermostat and ultimately the element.
regards
