I put in a bathroom in our basement two years ago, and I've been having frequent problems. The toilet, shower, sink, and laundry empty into the pit, and the way it was set up, it would dump right onto the ejector pump. Toilet paper and waste would get on the pump, causing the pump to continuously run (I'm not sure what triggers the pump to run, as I'm clueless with that and I wasn't the one to install it). I would have to go in about once a month to clean it off, and it would work fine after that. I later put a 45 elbow on the inlet in the pit, causing the water to hit the side instead of dumping out on the pump. This helped, but now I'm having the same problem again. What in the world am I doing wrong, and how can I fix this once and for all? Any help would be greatly appreciated.
