Hello-
This is directed at anyone who has experience installing the Grand Hall Eternal Tankless water heaters in a dual (or more) unit installation where two or more units are installed and using the BUS connection to communicate production based on demand.
I had these two units installed in my home three months ago by a local "reputable" plumbing company. Unfortunately the install was flawed from the beginning because they sent out plumbers who were inexperienced with installing these in dual configuration. The first round of problems came from them not knowing how to put it into multi-unit mode, then they broke a pin on a board which had to be replaced. Once they got htat done and the multi-unit configuration on the dip switches set, things seem to have been ok. I have noticed though the 'sandwich' effect every so often and sort of randomly since the units were installed.
We run these at 130f which should be hot enough to burn and not tolerate holding my hand under the water. While it gets close to being that hot, it's still not as hot as I would expect.
This evening I was in the utility room and decided to do some laymens testing to see if things were working. What I noticed was: The output line on the 1st unit was nice and warm, where the output line on the 2nd unit was luke-warm at best. The way the piping is setup, the 2nd unit's output line connects up with the 1st unit's and they blend the water out to the main feed to the mana-bloc.
I've included some photos below. The plumbing company swears they are hooked up properly because we can turn on tons of faucets in the house and they do lose pressure but not too much. I'm hoping someone can just tell me it's normal for the 2nd unit's output line to feel luke-warm while the main unit is nice and hot but I have a feeling something is wrong because I looked at the installation manual and it mentions a recirculation pump, which does not exist in my world presently.
Thoughts?? Thanks so much to anyone with some helpful advice on these things.
Images:
Unit#1 (Master)
Unit #2
Both Units Side by Side
-Ryan
Images:
Unit#1 (Master)
Unit #2
-Ryan
