My first post here, thank you for having me!
I have a septic system that I try to keep clear but no flushing any toilet paper, napkins, etc and I use ridx to keep the septic clean. I have a downstairs bathroom and two upstairs, three days ago the bathroom downstairs started to spill water, so I know right away what it was. We use coconut oil for frying food so I assume my pipe got greased up with such cold weather we had experienced lately. If someone flush upstairs there would be no problem if the second flush would take at least an hour or so, so there is some movement in there. So I went to the store and purchased a gallon of a very concentrated drain opener. I removed the toilet from downstairs, pour the gallon down and let it sit for 4 hours. I think that from my toilet upstairs to my septic tank there is a total of 30 feet, so I have a 1/2 50 feet snake which I used with very little problem all 50 feet! and as I was removing the snake I would dump boiling water down the drain in case any of that lye would stay on the snake since the smell is intense and that water would end up coming out of the toilet downstairs. The problem is that I am still having the same drain problem... I tried 3 more times to snake the drain... I even though that perhaps the snake was going out of the vent pipe, so I checked and no, that was not the case -at least that would had made some sense because this problem has me scratching my head.
Any thoughts?
Thanks in advance for your help!
Steven
Any thoughts?
Steven
