Double electric heater water
NewRookieOwner
Jun 19, 2023
Usa
Greetings,
As a new home owner, trying to learn the ins and out of things... apparently there are 2 electric water heaters (parallel?) in this house....can you please help identify the parts in the attached pic..i.e. which one is the main shut off/on valve.....or the purpose of small tank....does red mean hot and blue means cold.....or when it comes to flushing these units, you do one at a time or both same time....how...
I know...asking alot.
Thanks.
    688.2 KB
It’s not piped properly. You’re not getting the full benefit of two tanks.
The small tank on the left is a thermal expansion tank. Water expands when heated, this extra volume of water expands into this tank.
The two blue handles in the center of your pic turns off the cold water to each heater.
What are the red ones for? Is the one on far right the main shut off to the house? I guess the red and blues are confusing me.
Thanks
Thanks
I don’t know what the red ones are for. They appear to be cold water. Maybe outdoor hose faucets.
Don’t breathe on that cpvc……
In red, this may be your valve that turns all your water off to the home.
The valve circled in yellow is a pressure reducing valve. Aka PRV.
