The pipe doesn’t have a flange wrapped around it supporting its weight. Is it ok to just put down I new ring (notice space between new ring and pipe.
The split flange is slightly too big to slide under and I haven’t seen a similar ring that is smaller.The split flange should slide under the plastic then anchor it down with stainless hardy
The split flange is slightly too big to slide under a stay lines up with screw holes, which made me guess that I would have to install as is or fabricate something. I really don’t want to use one of those adapters that screws down into the pipe reducing its diameterThe split flange should slide under the plastic then anchor it down with stainless hardy
