samched
A little background: at my house, I have a submersible pump (no clue how old it is) that I suspect the check valve is shot. Several months ago I noticed my pressure tank short cycling (pump up to 60psi, and drop to 40 psi in about 20 seconds). The tank seemed fine and not water logged. I did not have a check valve at the tank tee. All this lead me to believe the check valve in the submersible was shot. As a temporary fix, I replaced the pressure tank and well tee (they were pretty old so figured I'd just replace while I was at it) and installed a new check valve at the well tee. My thought being the well tee check valve would at least temporarily serve the same role as the 'failed' check valve down in my pump and sustain my pressure. It worked; no more short cycling.
Despite seeming to have fixed the problem, my concern now is that even with a working check valve at the well tee, the water would still slowly work back down the pipe and into the well, introducing air in the pipe which would then push into the rest of the system. I've since noticed some indication of this at my bathroom faucet and showerhead, as SOMETIMES they sputter with air pockets blowing out when I first turn them on (never did this before). Also, I am noticing A LOT more bubbles in my water when filling up a glass compared to before these issues.
So, at this point in my limited plumbing knowledge, it seems I can confidently say the pump check valve is shot, and I should PROBABLY pull my pump and replace in the near future. Would you all agree? If I am correct and there is air in the system, does it really hurt anything? Maybe I can ride it out till my pump stops working entirely? I do have an acid neutralizer tank, could air in the system harm it at all?
Current system:
Thanks in advance
Current system:
Thanks in advance
