Hi, I have two showers that both have leaking diverters although all of the stems were replaced in 2020 (supposedly). Both showers are the 3 handle type. I matched the units to a Danco 9 in the hardware store. My diverter doesn't fit in unless I screw it to a shorter position which makes my diverter stem at least a quarter inch shorter than my cold/hot water stems. That being said, the hot and cold water operate great when running through the tub nozzle (no leaks at the hot/cold handles). When the diverter allows water to the shower head, about half of the stream comes out of the tub nozzle and half through the shower head. I thought this was a washer issue, so I purchased a replacement -- perhaps the wrong size (#11) or wrong location for the washer? I appreciate any advice as I only know enough plumbing knowledge to be dangerous.
Attached photos show the diverter opening, diverter with worn washer, diverter with washers side by side, and diverter with new washer installed.
