buck1109
Hi,
I am curious to know if a Fluidmaster 400 (a or ah) model Fill Valve can be totally disassembled (for cleaning)? (I've removed the cap and have let the water flush out the top area, although I'm still experiencing slow tank fill time. The bowl fills at normal speed. Also, I've removed the white 'corkscrew' water speed regulator, but the tank still fills slowly.)
I've been able to take most of the flush valve apart, with the exception of the chamber at the top of the 'tower' in which the water is diverted to the tank fill and the bowl fill. I've included a photo here.
I'm not sure if the white plastic part (with the 'spokes') is removable to reveal the rubber seal underneath?
Is there a breakaway diagram to show what happens under this area, where the water splits into the tank fill and bowl fill channels?
Thanks!
Thanks!
