DestroyerOfAll
hello all....i have a tankless coil in a weil/mclein boiler........there was an electric hot water heaqter in line but bypassed. i replaced it with a 50 gal bradford / white electric. what would be general high and low limits and differential be on my aquastat(tankless coil)....and the settings are set to "hot" on the water heater. right now the aquastat is 200/180 and 25 diff. also, mixing valve has just been changed. water is very hot....i probably shoud turn something down, just don't know where to lower...i'm thinking at the aquastat because it's just supplying the wh now.
thanks
thanks
