new Heat-Flo has been running fine since Dec install.
The boiler return is hot to the touch. The hot water out is warm at best.
The boiler is a Slant-Fin Bobcat installed in Nov. 2010. Is has been running fine, but I have heard some clicking from within on occasion.
No Error is indicated on boiler. But it seems to be cycling a lot. Every 3 to 5 minues. Outside temp is indicated on the panel as 55º but it is 43º.
dhw shows a temp of 180 to 210º.
return shows 139º.
no temp is shown on boiler for dhw. I'd have thought the Heat-Flo has a sensor in it, but perhaps just the aquastat to send to the boiler.
supply water temp is 194º
wp is around 15psi
whats wrong with this picture?
I just toggled the power switch to see if the Slant Fin needed a reset.
House heat is fine.
return shows 139º.
wp is around 15psi
House heat is fine.
