Hi All,
I'm looking for help with a rough in of a new bathroom. We've done an addition and changed an old bedroom into a bathroom. My questions are around the sewer line installation. Due to the location of the mainline I need to run a portion of pipe a long a horizontal support beam. Here are my questions:
1) The way the bathroom is setup the toilet and double sink are first and the tub and shower are across the room. Should the toilet be the last item on the 3" pipe, meaning that I need to hook the shower and bath into the 3"" line before the toilet or can I use a 3" tee wye (i think it's called that) for the toilet and a fitting that reduces the 3" down to a 2" pipe and continue on to the shower and tub?
2) I think all drainage pipes need to turn a corner with 2 x 45 degree fittings instead of a 90 degree fitting. Is this correct? Does that hold true for 3" pipes as well?
3) What is the maximum allowable distance a 2" drain pipe can be from the vent.
Thanks in advance for answering my questions.
Greg
Greg
