My Delta Addison faucet handle (one of the two) became corroded under the handle and needs to be replaced. Delta sent replacement parts, although they don't appear to be exact matches but before I can see if what they sent will work I need to get the old parts off.
I need to replace all the parts above the counter - the handle base and up. I know the new base has a tiny set screw that allows it to be separated from the support for the stem valve, but the one on the existing base does not appear to have a set screw anymore - I don't know if it just corroded away but I took a photo and blew it up and don't see any screw. I don't know if I need to remove the nut under the counter to get the base off or what. I was also not certain if the hoses needed to be disconnected or not to make this repair, but if they do I have no idea how to get the quick connects off.
I'm frankly baffled by this whole setup and have tried for hours but can't get the rest of the handle assembly off. I did try removing the nut under the counter with a basin wrench and that didn't work either.
Any thoughts or advice (short of calling a plumber) would be great.
