Hey all.
i live in bfe and i want to run my grey water out into a different leaching setup than my septic to cut dwn on excessive water in it.
I wanna run a main pipe from one end of the dbl wide to the other with a slight downward grade and out about 100 feet and into a leaching setup i have. I wanna simply cut the drain pipes from the washer....tub n shower and run em into the main pipe.
My question is this. All three things are located within 6feet of each other so are the drain pipes ran into the main sewer pipe in one place or into one pipe or are they usually ran into the sewer pipe each individually? I have a good insulation n plastic underpinning so i hate to tear it out doing an exploratory on it.
Tnx for any help. Rr
