I am in the process of moving my laundry up from the basement of the house.
The new drain line is going to be very challenging in terms of twists, turns and fall to get to the central drain line.
Because of that, I had a question, which I guess is a bit unconventional.
Can you use a larger, maybe 2 inch, pex line as a drain for a washing machine?
Let me know what your thoughts are for or against?
If it is not possible, I can do the run with abs pipe, but I would love to save myself the aggravation of navigating the path if possible.
Thanks
Thanks
