couple questions on new main sewer line
well worked most the day, got done would most you guys would probaly do in 20 minutes
any obvious problems?
should i stake the pipe in place with something before i finish backfilling?
ok last one
is there any issue with coupling a couple 1/8 bends togther like this to form like an ogee offset?
why the offset ? an offset is a potential spot for a clog
code wise, nothing wrong at all,
did you start at the high end ? working tward the low ?
should have started at the low, and worked to the high
in post 21, the wye by the sawzall, that is for a future bathroom ?
what is the measurement from top of concrete to center of pipe ? looks high
easy to do, throw a board over the ditch and measure from board to center.
how far from that wye is the bathroom ?
i have to offset either way, to follow the old trench, its solid sandstone around it or i would dig
with the double, i have a better angle at the FD
yea i started from the stack to low
it saved my washtub in the basement and i hosed all the waste down the 4 foot piece of line i left downstream until today
i have a self leveling laser clamped on a piece of angle over the trench
yea its for bathroom , i was just going to put a short piece with a cap on it and worry about it after the summer
ill go measure
4 inches? to close?
the bathroom would be a few feet
was just gonna put it up against that backwall starting a few feet from the stack
just a stand up shower and a toilet
are you refferring to the stack as concrete pipe?
its actually painted CI , i cut it and went to pvc at the mission
its a foot from the wall
it starts at 4"depth , the wye is actually 5 , and im 8 feet out so far on the main, with a 2 inch fall
i can put the bathroom as close or far from pipe as i want/or leaves enough clearence to stack
its 8 inches plus the buried trap and 75 inches from the wall
im on a solid slab of rock above the trap
i had to put a pointed chisel on the macho hammer and chip away for an hour to have a place to sink the trap
im gonna go cut the wye out and couple a piece in there while i still have all the play
i redid it
thanks for catching that for me, this look ok?
no....sorry confused you
from what ever it is you are tieing into, what is the depth of that pipe from the floor to center line of pipe.
take that measurement. assume it is 10
now take the total footage of the pipe to the bathroom from the tie in
lets say it is 10'@ 1/4'' per ft all for 3'' pipe.= is 2.5''
at the bathroom center of pipe will be 10''- 7.5''
concrete is 3.5'' that leaves you 4''.. that aint enough using these numbers
Ok. I moved it to the last wye in the pic
It is seven inches from top center ti floor
About 7-8 feet from bathroom
7'' 1/8'' fall per ft x 8'=1'' so at bathroom you have 6'' top of concrete to center line
you got a 2 combo ? and a2'' 22.5degree bend ?
hold the22 on the combo, and roll the combo till the 22 is level
what is measurement centerline to top of rollled 22 ?
