Copper to IPS valve
Bill Stock
May 6, 2018
I want to connect the copper Hot and Cold lines to a Thermostatic valve. The Thermostatic valve has three male IPS fittings. I will also need a couple of check valves; most I have seen are female IPS to female IPS.
Ideally I'd like to use a union, so I can remove the valve if I have too, but this seems overly complicated. I was thinking of valve (Male IPS) to Check Valve (Female IPS) to Copper Male Adapter (Male IPS).
I've also seen Unions for the last piece and SharkBite Tees with a FIP connection for the supply lines.
Any bright ideas?
Show us what you are talking about. Pictures please.
What kind of space are you talking about placing this in?
Not enough information.
