copper to flex kitchen sink.. please help
imig93
Active Member
Sep 1, 2021
30
pittsburgh
Thank you in advance for your reply I want to replace my old copper pipe flex line…. how will i do it? below is a picture
    1.5 MB
you could put some 1/2" sweat x 3/8" compression adapters on the copper after the ball valves. You could also turn off the water and remove the ball valves and put some compression angle stops on.
thank you
tha k you for your reply … will the compression adapters require saudering?
Why are you replacing them?
i figured it would be easier when installing a new sink as opposed to connecting the sink right where those copper pipes currently are(it may not line up right???and seems outdated )
Cut the copper pipe right below the reducing fittings. Make sure you get as close as possible so you have enough copper left
above those valves. Then put on 5/8" x 3/8" compression couplings and then you won't have to do any soldering. A lot of new
kitchen faucets have the supply lines already attached to the faucet. Then all you have to do is hook to the top of the compression
coupling.
coupling.
coupling.
5/8x3/8 compression coupling? it looks like 3/4 when i measured it(the lower copper piece) and i thought most sinks and stuff are 1/2 ? wouldnt that be a 3/4x1/2 coupling? or is that all wrong lol thanks for help
Are you saying the OD of the copper pipe coming out of the wall is 3/4"? Sure looks like 1/2", but again, pictures can be deceiving.
If it doesn't measure 5/8 on the outside then I can't tell by the picture if its 3/4 or not.
gotcha…. so i cut it but its dripping from the ball valve it seems? should i just turn the main water off, remove ball valves and put a compression angle stop on? like someone else suggested?
i might have to do your second suggestion i cut the copper but it seems to be dripping a little from valve
