Connecting two hoses to creater shower
djdenali
Nov 13, 2013
7
Outside, I have a hot line and cold line in two separate garden hoses. These run to a bathtub that is too far from the nozzles to adjust once you're in the tub. What would be the best way to create a shower type situation that we could post to nearby wall or vertical board. Being outdoors, function and low cost prevail over aesthetics this time. Suggestions would be most appreciated...thanks. dj
you might have to install check valves if the cold pressure is more than the hot pressure
this is not something you want to leave on, all the time
the rest of your system will have crosssed water while usiing this/
this is temp/ camping/ survival/ not permanent
