Andrew Rivera
- Joined
- Apr 16, 2018
- Messages
- 5
- Reaction score
- 0
Hello all,
I am new to this forum and am in need of some advice concerning my current DIY project. Let me give you guys some back ground first.
I live on a slab and was in the process of replacing my laminate floors in my den when I noticed a small puddle of water on my floor, underneath the moisture barrier:
At this point I stopped the new laminate install and started to try and figure out where this water was coming from. The cement was warm/hot in that area so I figured it was a hot water pipe, so at this point I placed a plastic bag over the area and taped it down. The next morning when I removed the bag the bag was wet and I had wet spots on the floor:
Having had an issue before with a hot water pipe bursting and destroying my laminate floor in the living room, I am very wary about laying down the new laminate before I figure out where this moisture is coming from. I checked the water meter and I didn't notice it moving at all when the water is off in the house. So I figured I need to look at the pipe and give it a visual inspection and I proceeded to jack hammer the floor to see if I had a slow leak under my slab.
I jack hammered about 8 Ft. of cement:
This is where I am starting to feel lost
I don't see a leak of any sort, I did notice the sand around the pipe was moist and warm to hot but this makes sense because it is a hot water pipe.
I placed another plastic bag over the exposed pipe, taped it down and this morning of course it was very wet because of the condensation from the pipe.
My question is at this point how do I fix this ?
My only idea is to:
Any suggestion, comments or ideas are welcomed ...
Thanks
My only idea is to:
- Replace the exposed pipe with "PEX" . (If you looked at the 1st thumbnail the pipe was already fixed at some point with "PEX", I was thinking of just cutting the pipe at the far end and running "PEX")
- Seal the cement with "cement moisture sealer"
Thanks
