shaken-n-stirred
Clean out questions:
1. If I have a glued up P-Trap for a tub which has access from below, is a cleanout required by code? And if so, where (just after the trap? Side entry?)
2. Do I need clean-put on vent piping? Seems odd, but I have read some about it. What are the rules? Most vents are buried in walls, so obviously no clean outs. Some vents tee together in attic spaces, so are vents required and if so where?
3. IF I have toilet with a drain running parallel in a joist bay and no why to get a vertical vent up off the drain in the required 5 or is it 6 feet, can one run a parallel vent above the drain teeing off need the closet flange and running parallel until it can run vertical (and of course you could also have that vertical vent tie into both the horizontal drain and vent at that point)?????????
