It is a simple S trap open pipe that serves as the drain for the dehumidifier that sits next to the drain. This is how I determined that the drain was clogged - because water was pouring out of this as my daughter was showering...fun cleanup!Separate subject but what is that line that looks like it's connected to that drain line?
if you look on the outside of the clean out....those threads are lead ….that looks like whats called a (lead fit all plug) they are used when the threads on the cast iron fitting are rotted out or no good...so the (lead fit all) is just tapped into the cleanout so use a hammer tap the nut from side to side it should come right out....the threads are lead that's why it taps in...
I believe he said, "An internally threaded collar is leaded into the bell of the off leg of the 4" iron y-pipe joint; the cleanout plug screws into that. The collar and plug began to move in the lead.", which I believe means he's going to end up with a bell joint because the leaded in collar is coming out with the CO plug.If it is a brass plug just cut it out and replace it with a pvc threaded plug.
Of course he may still have the option to re-caulk the leaded joint with caulking chisel and hammer. But he would have to have the proper chisels and know how to do it properly.
