Yes, this is a plumbing question! Sort of...
We have to open up our entire sewer line by cutting a trench through our slab basement floor. The cement guy says he will hang plastic sheeting and use a vacuum (not sure if it is a wet vacuum or not...).
I'm worried about cement dust getting into our freezer compressor (or whatever it is called). Even though it will be outside of the plastic sheeting I know there will be a lot of dust that will get through and certainly when they take down the sheeting.
Does anyone have a recommendation of how to protect the freezer from the dust? Does it have to be removed from the space until the slab is re-poured and the final cleanup is done?
Someone suggested a mattress cover just slipped over the top and pulled down. Would that work or restrict the air flow too much?
Thanks
AnnC.
Thanks
AnnC.
