P phishfood Professional Professional Supporting Member Joined Jan 17, 2010 Messages 5,775 Reaction score 1,000 Location Orlando, FL Dec 5, 2014 #41 Just checked the current Florida code, and it does list such a pipe as being an approved pipe for above ground drainage, waste, and vent pipe.
P phishfood Professional Professional Supporting Member Joined Jan 17, 2010 Messages 5,775 Reaction score 1,000 Location Orlando, FL Dec 5, 2014 #42 And I agree with havasu and frodo. Fix it as "right" as possible.
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,977 Location right here right now, over there later on. Dec 6, 2014 #43 yeah, that is the celurcore pipe. for dwv only. not pressure. it was the big thing in the 80's. to save a buck half the weight as sch 40 pipe. half the cost
P phishfood Professional Professional Supporting Member Joined Jan 17, 2010 Messages 5,775 Reaction score 1,000 Location Orlando, FL Dec 6, 2014 #44 Cellular core pipe still gets used a lot around here, but it is still Sch 40 pipe, with a 3 1/2" OD.
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,977 Location right here right now, over there later on. Dec 6, 2014 #45 cellurar core pipe is to pvc pipe like whipped margerine is to butter. yes it is but it aint!!!!!!! that stuff is a pita to cut out of a fitting if you used cleaner
R RTchips Active Member Joined Nov 22, 2014 Messages 40 Reaction score 0 Location , Dec 6, 2014 #46 Use something like this?
R RTchips Active Member Joined Nov 22, 2014 Messages 40 Reaction score 0 Location , Dec 6, 2014 #47 Should I just take a sawzall to it and cut enough out to slip that thing over it? Here is the gash cleaned up before I put that epoxy stuff on...
R RTchips Active Member Joined Nov 22, 2014 Messages 40 Reaction score 0 Location , Dec 6, 2014 #48 So the drywall is touching the pipe. . Will there still be room if I put a sleeve on still? Seems like there would be no room to do that
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,977 Location right here right now, over there later on. Dec 6, 2014 #49 cowboy up airborne, if it dont fit force it. physically manipulate with great prejudice hand me a bigger hammer, I'll fix the SOB!!!!!! Last edited: Dec 6, 2014
R RTchips Active Member Joined Nov 22, 2014 Messages 40 Reaction score 0 Location , Dec 6, 2014 #50 At the store, its not going to fit
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,977 Location right here right now, over there later on. Dec 6, 2014 #51 dude, cut the rock out. if you have to patch back with 3/8" rock or 1/4" rock instead of 1/2" do it. little extra mud and fiberglass tape no one will ever know http://www.lowes.com/pd_11717-325-14101013408_4294858283__ use your pocket knife, shave the rock down thin, what ever it takes
D DFBonnett Professional Professional Joined Jan 16, 2010 Messages 234 Reaction score 39 Location Twp. of Washington, New Jerky Dec 7, 2014 #52 OP, If that same pipe vents through the roof, check for water infiltration there.
R RTchips Active Member Joined Nov 22, 2014 Messages 40 Reaction score 0 Location , Dec 7, 2014 #53 Here it is
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,977 Location right here right now, over there later on. Dec 7, 2014 #54 wrong band. no wonder it wont fit. cover it up before phishfood or matt sees it !!!!!!!! Last edited: Dec 7, 2014
R RTchips Active Member Joined Nov 22, 2014 Messages 40 Reaction score 0 Location , Dec 7, 2014 #55 The one I put non is wrong? I didnt put the one on that you posted
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,977 Location right here right now, over there later on. Dec 7, 2014 #56 the one you put on, does not fit, look at it. is that a drain or a vent? if its a drain in needs to have a smooth drain way inside or it will catch stuff and clog up the band i posted wil give you that correct fit. it is also thinner, which will help with your sheet rock problem
R RTchips Active Member Joined Nov 22, 2014 Messages 40 Reaction score 0 Location , Dec 7, 2014 #57 The inside was smooth... This is a pic of the label. I did test it and no leak.. It is a drain from tub/shower
R RTchips Active Member Joined Nov 22, 2014 Messages 40 Reaction score 0 Location , Dec 7, 2014 #58 I guess I will go get the correct one. The home depot has some. Sigh the od is 3.25. This one iI got seemed big and it was 3x3. I want to get the correct one so do you know what size to get?
R RTchips Active Member Joined Nov 22, 2014 Messages 40 Reaction score 0 Location , Dec 7, 2014 #59 It looks like the difference is sheilded vs. Flexible?
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,977 Location right here right now, over there later on. Dec 7, 2014 #60 you need to get a mision band size is 3" plastic x 3" plastic= 3"pl x 3"pl that is how they are sized plxpl go to a plumbing supply, not ho depo ask the guy behind the counter
