I have caulked many joints in my 50 years as a contractor. Most of which have been tested. Many of these joints the lead was caulked well after they cooled. I'm not sure of the method of testing you are referring to but the way are joints were tested was to cap and fill the lines until it overflowed the vent above the roof. (in many cases it was two or more stories. Even when there was a occasional all that was required to fix it was to do a little more caulking of the now many day old cooled lead.
John
"Hello John",
What You describe as having `Done all of Your Working Life` - words to that effect IS probably the `Norm` here in the U.K. also regarding Caulking Poured Lead Joints or Re-Caulking / `Tapping Up` long after the Joint being poured.
But I was explaining to a `Novice` / `Learner` how to Caulk Joints in the BEST Way - Although He has written that He MAY want to do this occasionally to Help Friends etc. - He probably will NOT be carrying out very many of these Joints - and almost certainly NOT in a Time Sensitive / Piece Work / Commercially Tight Circumstance.
The reason that People do NOT Caulk Joints when Hot is usually because THEY do NOT see it as `Necessary` - They feel that this Method is just a `Delay` in pouring a Number of Joints - NOT because it is not the Correct Way to do it.
Regarding the Testing that I was referring to:
As You know Air will escape where Water will NOT - I am referring to Air Testing of Above Ground Cast Iron Drainage / Cast Iron Soil & Waste Water Pipework - Especially where these Pipes are Installed within a Building.
Pipework that does NOT Leak when Water Tested is NOT necessarily `Safe` from the escape of Methane / Bacteria etc. - I am sure that We have all experienced the situation where a Bad Smell pervades a Property - because of some kind of escape of the Smell / Methane / Bacteria from the Drainage System.
Although a small Air Leak would not normally cause any Problems because of the size of the Vent Stack in comparison to a `Slight Air Leak` - there CAN be escapes of Bacteria / Methane etc. - in the U.K. We Air Test ALL Above Ground Drainage / Soil & Waste Water Stacks / Waste Pipes - Again I ASSUMED that this would be a Method of Testing in the Plumbing Industry in the U.S.
By the Way - I do know the `Old Saying` about `Assume`.
From what You wrote this is obviously another example of `We don`t do that in the U.S.` - So I have found another reason why I am wasting My Time by Posting on this Forum.
Thank You for enlightening Me - Indirectly - by Your comments about this Difference / Not used in the U.S. - regarding Methods of Testing.
CHRISM
