Hello,
My cast iron drain from kitchen seems to have decayed near a joint.
My thought was to use a reciprocating saw or "snap cutter" to make two cuts one foot away from the join on each side. Then I plan on inserting a section of PVC with "fernco rubber coupling" with stainless steel clamps (not sure if shielded is needed).
Is this a good idea?
Also, I was thinking of lifting the cast iron out of the mud and clamping them to the underside of the house with one of those metal straps with holes in them. Is there a risk of breaking some of the other joints?
Alternatively, someone suggested replacing the whole line with PVC.
The image shows the problem. Any suggestions appreciated. Thanks.
