- Joined
- Sep 28, 2014
- Messages
- 8,578
- Reaction score
- 2,977
i
Please expand, when i said i needed to connect pvc to a 1.5 remail threaded hole in a iron drain i was handed a pvc adaptor, male threads one side and you cement your 1.5 pvc pipe in the other end, im sure you know the piece,
That's how I would do it. Some where I read you wanted to use 2 threaded fittings? Plastic female fittings have a greater potential for splitting when a male fitting is screwed into it. I would not normally do what is described in the following sentence .
Now if i am understanding you , you are saying dont do that it will cause problems but rather get a stub piece of "metal" pipe screw it into the iron pipe then use one of the shielded rubber couplers to connect that metal stub to the pvc,
If I had to screw a metal nipple into the iron pipe female threaded hole, I would use a brass nipple.
B
This can be a whole new discussion on that statement.Never thread dissimilar materials such as plastic and metal pipes together. Recipe for disaster. Always install a short ~3-4" stub out of new metal pipe nipple in a female metal fitting. Use a shielded no-hub coupling, NOT the rubber only Fernco type, SHIELDED only to connect the new pipe stub to the plastic pipe.
How can screwing a plastic fitting into and iron fitting be a recipe for disaster?
I peel out DWV copper trap arms from threaded cast iron tapped tees and replace with male threaded plastic ABS fitting all the time.
Sure beats ripping open the wall and chopping out the whole Sanitary tee.
Back in the old days even before my time It was all leaded or threaded.
So sometimes you do use threaded...
I explained why in my original post,
But to further clarify, i am trying not to tear all the floor out, sure i know that is what a "professional" would insist on doing ( partly to charge more ) but i tend to think more outside the box with stuff, and to me screwing the tub drain pipe in would be easier than trying to get it that 3 feet under the floor to the T all dripping cement making using primer then cement very hard to pull off,
Theres a lot of irony to me for it to be a big thumbs up to use a pvc threaded adaptor into the iron pipe but dont use threaded pvc to pvc
Dear frodo, the code that you listed clearly states (and you put it into large letters) 'in inaccessible locations' that means places that cannot be reached easily. The reason given is collection of gunk to shorten the argument. Your statement is correct in this case but your attitude and BS is wrong. His location is not inaccessible and what accessible is can be easily corrected by making an access panel.That is it, there is no damn argument on this point
I am working on a 100 plus yo upstairs bathroom,
I needed to replace the old rusty plugged up galvanized sink
Your out of line here - what is the point in doing that? He is in alignment with the code - even you can read that if you wanted to. So, yes there is argument over your interpretation of his situation. Where he wants to put the threaded stuff is accessible unless 'accessible' took on a new meaning because you say so.
true.
tapped tees are straight threads and female adapters are beveled threads
the male thread mip, when it threads into a female adaptor fip
will not go all the way in, there will be female threads visible, these threads will catch gunk
a threaded plumbing system than uses straight threads so that the inside of the pipe is smooth with out
pockets to catch stuff is called a durham system
Is this really how you feel, why didn't you say so? Was I so far wrong when I said that some of you pretend that you are gods? You want to help somebody or do you just want to drive everyone else away from a perfectly good site? There is no excuse for this kind of conduct and if you are not censured for it I will be gone. Life is to short to put up with this kind of inane BS.I do not need you to speak up for someone else, You are not a mod
Do not try and school me again with your ******** , be gone
Yeah, kind of surprised this threads still going.
Then leave lol. Not that hard guy, if you need a safespace then go elsewhere.Is this really how you feel, why didn't you say so? Was I so far wrong when I said that some of you pretend that you are gods? You want to help somebody or do you just want to drive everyone else away from a perfectly good site? There is no excuse for this kind of conduct and if you are not censured for it I will be gone. Life is to short to put up with this kind of inane BS.
true.
I am working on a 100 plus yo upstairs bathroom ,
I needed to replace the old rusty plugged up galvanized sink and tub drains
The catch i wanted to bust as little of the floor as possible ,
The rectangle room has the old but good iron main drain toilet on top at one cornor,
Then the other cornor has the sink, the tub drain was T,ed into that sink drain, it goes to the side of the iron pipe behind where the toilet sits on it,
I got all the old pipe out wasnt easy, nice threaded 1.5 hole in the iron stand pipe to connect to, wasn't easy getting that rusted galvanized threads out of there,
My original plan was to cement the pieces and pipe ( pvc ) together as i assembled worked them into their space , in the floor,
But dawned on me with it cemented together it would have to be cut to do any service and getting it all together with some connection out of reach with cement would be a bit tricky, not impossible but difficult.
So can i use pvc threaded fittings on the pvc pipe and just screw sections together, no pressure just a tub and sink drain, is pink tape what to use on the threads, or is there a sealer for this some places will still be cemented together but for example screwing the tub drain pipe into the T with make it so much easier,
If i can do it with some threads fittings it would make it easier and give me peace of mind i could service it without cutting it out,
Okay...clue me in,
Thanks
b
I like Frodo, Glad he's back. I missed him and like most of his input, But I'm going to take sides with jwwing.
I don't think he was out of line. I try not to correct others when they are wrong. I just move on.
I did notice that Frodo's snip of the code said female and inaccessible, and really did not apply.
Okay I'm done.
I stopped in to link a thread I did awhile back. In regards to replacing DWV trap arm in a tapped Sanitary tee.
It's kind of related
https://www.plumbingforums.com/threads/how-to-repair-dwv-copper-trap-arm.6382/
Wow, I'm not feeling the love.![]()
