I had a new 80% gas furnace installed which shared a common flue up thru the roof. the old furnace was naturally vented without a draft inducer. Now when the draft inducer kicks on there is a brief backdraft at the top of the water heater until the main burner fires, then it draws well. on the water heater there is a vertical pipe leading to a slowly angled up horizontal run to the main B stack. I wonder if increasing the angle or placing a small piece of sheet metal angled up where the water heater flue enters the B stack to prevent the inducer draft motor from blowing towards the water heater would help. Thank you for advice.
