Hello,
I have a 50 gallon Bradford White Defender gas water heater. It was the wh that was installed in my house that I purchased in February 2021. I am the first owner. It is now very slowly heating up water. Basically only one shower before it gets cold and it takes probably overnight to heat up again. I cranked up the temperture and it has helped some. The gas valve on this is an Icon System which I understand to be a rebranded honeywell. I have checked the basic things on it : i.e flue, thermopile voltage (350 -370 mv), etc. What I have noticed is that the status light flashes green every second. The label states this is not an error, this just basically means that the main burner is on. The problem is that the main burner is not on. I have tried turning of the unit completely and restarting the pilot. The pilot lights up and stays on no problem. When I go through the reset procedure, the light goes to blinking once every 4 seconds. According to the label that is the blinking status when only the pilot is on. When I move to dial to hot the main burner fires up with a swoosh sound and the light sarts blinking every second as expected. After 2-30 seconds the main burner turns off again but the light continues to blink every second. I have removed the burner and looked at the pilot, and thermopile. The thermopile does not see to have any crud on it and still looks fairly new. Are these valves supposed to alternate their modes and reflect that with the appropriate blink codes i.e when the main burner is not on it should blink once every four seconds or does it always blink every second after it turns the main burner on the first time?
Has anyone seen anything similar?
What else should I test?
This wh is still under warranty but it seems like only a licensed plumber can request replacement Are there additional costs involved after the warranty?
