drunknpirate
I just bought a building in March. During early spring when I had the heat on I had no problems with the boiler. Now that winter is kicking in and the heat is back on the pressure relief valve is pissing out water when the system is running. It is a gas fired hot water system. The psi is at 20 when at rest and reaches 35-40 psi while running. The vavle is rated at 30psi so I understand why its leaking but I don't know why the system is reaching this high of pressure. I never bothered to check the psi this past spring since there were no leaks.
I have drained the expansion tank which had no effect. The building is running cast iron heaters. I have the pipes running upstairs shut off because I had to remove the cast iron to sand the floors. They should be hooked back up sometime this week. Is the high pressure caused by half the system shut off? Is the higher then normall pressure causing any harm to the system? The upstairs has its own pump and thermostat.
