Blue-skying a bathroom drain issue as well as odor....
cgilley
Supporting Member
Apr 5, 2023
187
101
North Georgia
So, a year or so ago, I had my bathroom re-done by a guy who has done good work for me before (mainly decks, but he also does addition and new home construction). A year later, I'm sort of suffering death by his subcontractors (long story). It's at such a state (don't get me started on the HVAC guys), I don't think it's fixtures any more. Anyway, today's question is about bathroom vanities and slow drains. The sink itself is a basic sink with an overflow hole. Under the sink to connect to the drain line, the vanity uses this flexible pipe. Because we replaced the original single piece large vanity with two standup units, there was some plumbing work done in the wall where the original plumbing lived - just extending/moving it to match the new vanities.
Ever since the bathroom was completed, the vanities drain weird. Some times they drain at the speed you would expect, but 80% of the time, things are slow. It can take 2 minutes for the bowl to empty. One theory I have is that the flexible hoses just don't drain as fast. That was suggested by the contractor, but I'm declaring BS on this. If I stick my head under the vanity into the cabinet, I get a distinct odor. Hmm. Nothing was done to the vent stacks. FWIW, also in the bathroom is a toilet (no issues there) and a shower that drains fine but initially had a plug issue that I thought the contractor had cleared but I'm starting to wonder.
How would you start chasing this down other than calling a plumber? :)
    108.6 KB
Those flexibles at TROUBLE. That may not be your problem, but I would HIGHLY recommend you replace them with regular P-traps. The next thing to confirm is that the sinks are vented properly. The vents are probably in the wall, so there may be something funny with the way the single sink to double sink modifications were done. Hard to trouble shoot without opening up the wall. I assume no pictures taken.
Remove that trash immediately. Get a plumber in there to hook up a 1 1/2" trap and then see how it drains. You could also pull out the stopper if you have one to see if that helps.
Mic-Ed - I completely agree. There are other issues with these Glacier Bay vanities, sigh. I did not pick them. My wife is like a AIM9X sidewinder missile. Once she locks on, there is no turning her back. There is no mercy either. :)
CT - I have a wedding on Sunday - last daughter - so it's on my list. Along with a life's work worth of house repair work and elderly in-laws (FIL is driving me bat **** crazy).
So, a brief follow up on this month's later. I took a hard look at the vanity and the plumbing. The reason they used the flexible hose is due to the structure of the vanity. For me to put in a standard rigid p-trap, I'm going to have to break out the saws-all and hack underneath the cabinet.
It's hard to tell but measure from the wall to the center of the pipe clamped onto the sink
You may be able to use one of those plastic tubular traps to use you drains may be be slow because they washed grout, mastic,paint down the drain you could remove the trap snake the drain and see what happens
