cactuscake
In February this year the drain under my tub started leaking. There was quite a mixture of pipes - brass fittings attached to the tub, a chromed copper pipe leading from the bottom of the brass fittings making its way to the black plastic coupling in this picture. The metal had corroded at both ends of the chrome middle section and we had a plumber replace as much as he could with white PVC, it took about 2 hours because of the awkward space.
Unfortunately the joint between white and black has started leaking again and I'd like to fix it. I can't tell what type of plastic the black section is though.
What I can see of the text says "...WHITE PVC-I) (off-DWV U 1 1/2 2744 UFC MA..." it is in an incredibly awkward space and it was only by sticking the camera into a hole and taking a snapshot that I was even able to get an idea of where the leak was coming from. Other than that the repairs will need to be done by feeling around.
I'm trying to figure out if I can just reglue the joint and if so, whether I'll need some of the green transition stuff, or if purple will work just fine.
Any ideas?
Any ideas?
