Since I can't screw the usual bidet Tee to my toilet reservoir, I would like the tubing to go through a wall passthrough and connect it to my general basement plumbing using PEX.
My biggest issue comes from the weird fitting on the unit's water line. Ideally I'd find a "weird to pex" connector, but I'm not very optimistic. An alternative would be to use the supplied Tee, cap the top and feed the bottom though a normal toilet water supply hose.
The toilet is a DXW Cossu D23010S000.415
The seat is a DXV AT100
Any help would be very appreciated!
