Chrism:
>>>MY Opinion is also that Pipe Thread Tape - PTFE Tape [Teflon]- is a Much Better Jointing Method than Jointing Paste [`Pipe Dope`].<<<
You have to watch those categorical statements, like all sealers they have their good and bad applications; get yourself some sharp fittings and see how fast the tape is cut off when you try to put it together.
>>>Here in the U.K. there is also a `Specific` PTFE Tape for use on GAS - This is a `Different Specification` to the PTFE Tape for use on Joints carrying Water - This Gas PTFE Tape is also much Thicker/ Different Consistancy.<<<
In most of the areas in the U.S. they also have a specific tape for gas but, there are a lot of people that chose to ignore it.
>>>The `Ordinary` PTFE Tape - for Water - is NOT allowed for use on GAS Pipe work Joints<<<
Just like my other answer said, but another problem is that some people use the imported (China) tape and it is extremely thin and shouldn't be used on anything in my opinion.
>>>I have previously Questioned their Findings relating to that point - As I wanted to know what THEY meant about the Tape being `Too Thin`- and why applying More Turns of Tape would not rectify that point - I received the reply that this formed `Part` of their Findings and was an `Additional Reason` for the `Basic PTFE Tape` being Prohibited for use on Threads for Gas Pipoe work.<<<
What I was told years ago when tape became common was that it would come apart and thin pieces could get into the gas line and stop up the orifices; if you ever took a white tape joint apart you can see where it becomes chewed up in little pieces, the gas specific tape doesn't do that, keeping it off the end of the threads would help also.
I have an suspicion that you have just as many people that ignore the rules in the U.K. as we do in the U.S., it doesn't look like the rules are that much different.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
