Hi guys, I’m installing a new bathtub and the drain/overflow aren’t very square with each other...leaving me having to glue the fittings on a slight angle (I do understand how the tapered gasket works on the overflow btw) Everything just seems to have to be pulled badly together to make it work. With all that said, should I go with a flexible coupling on the overflow pipe or a flexible tee?!?
Any thoughts are appreciated!
