Hi,
I have a danco tub faucet and I had a plumber just replace the cartridge with a moen replacement as it was leaking.
Now what happens is the metal handle is real loose and does not stay in the hot or cold position. It just falls down to the center.
We then replaced it with the plastic knob and when you pull it out to turn the water, the knob starts suckling back into the off position. You have to pull it out a few times in order for it to keep the water running.
My plumber never saw this so I am hoping some ran into this issue before and found the answer.
Thanks
Thanks
